(delete)engine spluttering on mk3 spi
it starts and runs really ruff wen driving (other than full throttle) seems to cut out and bk in agen .
changed throttle body still the same changed butterfly hosing (bit under throttle body) no change cheaked wirers no damage had new dizzy cap and arm no change.
Edited by joey87
  • Replies 10
  • Views 1.7k
leads/dizzy cap/rotor arm/coil...
Have u checked/replaced any of those?
Yeah, sounds like a mis fire.
change all the items martin mentioned. if it's still happening you may need to have your timing adjusted.
J
tried the fuel filter?
any leaks on the inlet manifold?
check the leads even if they are new. polos seem to be very picky when it comes to leads. stick a multi meter on them on the ohms setting check they all give the the same reading if not ones buggered.
is your earth connections ok? as that could feck everything up and is easily sorted especially the one at the lambda probe.
Edited by genesisGT
lamba probe?
where is the earth on that thought it was jus hard wired
an the hoist point nr the dizzy you will see about 2/3 earths joining there to a screw.
i'd be awayed to check the idle control valve if it runs rough without any throttle applied. I maybe wrong tho.
SPI's don't have an ISV...
thats the little black box on the front of the TB isnt it? thats adjustable on the throttle arm, theres a little screw on that you can adjust to change the idle.
Failing that try adjusting the TPS, thats the black panel on the side of the TB, all you need is to lossen the 4 screws and turn it back or fourth until the engine idles better.
think i burnt a valve out tryed leads n plugs and earths no diff then started compresion testing an number 1 holds next to no pressure :cry:.
thanks for all ideas any way weekend strip skim n build ahead
