How would I re-trim this part of my door cards
Alright people, any idea how I would go about trimming this section of the door in vinyl/leather material?
Would I just cut a bit to the right shape and spray adhesive on it and stick it on?
Or is there a way of removing just this section and wrapping the trim on and then somehow sticking it back together?
I know it would probably be easier to buy colour concept cards, but I will be customising the door cards to make speaker pods, so I wanna give trimming a go aswel.
  • Views 1k
if i was you....
take the door card off and then at the rear of the door card theres 4 bolts holding the plastic handel you use to close the door on, undo them and take that off, sand that horrible rubbery stuff off them and spray them satin black.
Whilst thats off using spray on adishive as you have said to apply the material to the doorcard it should be easy whilst that handle is off.
Would it all be smooth though by just sanding?
I heard that you had to use a special type of filler primer to get it smooth?
Also, with regards to the retrim, are you saying that I should just cut the material to shape and stick it on?
Apparently the bit I am interested in re-trimming can be removed, as it is just hot glued from behind so it can be cut off?
Is this true?
i didnt use filler primer when i did my handels in satin black and they look sweet. i dont know about you handels but that rubber coating that is on them started comming off and they looked all mankey.
I'm not sure about it being glued on so i cant really say.
if you take the door card off and you can see a join line from behind then its more than likely to be glued on.
*edit: i used p120 to get the rubber shite off then used p1200 before i sprayed them.
(dont use lacuer on satin by the way, you prob already know this)
Edited by Stonez
I can imagine the handle being easy to do, but I am more confused about how I would tidy up the whole door card afterwards.
you could just send it to plush and pay for them to do it lol?
