Help With Igniton Timing & Timing Belt etc..
Could anyone please send me a link/photo/copy of Haynes manual showing how to do the ignition timing on a mk2 polo (C Reg) with a timing light..
I have done it before on a mk2 golf so should be confident but just need something to follow 8-)
also need something to show where the timing marks are etc to help with fitting new cam belt after I have fitted my skimmed head..
Cheers, AddHone.
  • Views 1.2k
theres a link in the engine section of this forum to a pdf file of a mk3 haynes manual, might apply to some of the mk2 engines aswell.
Edited by Bronzer
If the mk2 has the same markings as the mk3 then:
On the Cam there is a small dimple on the pulley that should be facing 6 o clock, and on the pulley theres a dash and that should be at 12.
Not sure on timing as i dont think it is the same on the carb engines as the injections, but if it is you loosen the 2 bolts on the dizzy and turn it back and fourth until the mark lines up with the TDC mark.
Will try and find that now, cheers! :-D
Awesome, Thank you!!
hopefully should be easier to set up than my bloody mk2 golf GTI with digifant hell anyway :lol:
