Respraying ?
The car i have at the moment is dragon green but has alot off scratches and blemishes in the paint work so was thinking of respraying myself in matt black, was wanting to go for something like this;
i was going to do it with spray cans jus, i know i need to sand it all down, do 2 coats of primer and after first make sure its all smooth then spray second then do few coats of paint and then lacquer, has anyone done this before and if so could they talk me through this?
  • Views 918
no need to prime sound original paint...only any bare metal or repairs
scuff if with a scotch pad , then 3 coats of stain black, no need for clear coat if you buy single layer
That picture is what made me do mine..
I sanded down and they just sprayed.. turned out ok, but I didn't laquer it.. I think I will though, as the paint peels off! Just need to find a satin laquer!
so get rid of the rust then just roughly sand it down and spray it with satin black?
how hard is it to do the doors?
just remove them and spray them then spray the sills, think ill leave the engine dragon green for now lol
any pics off your car T700BES?
Edited by kennie
depends really, if you're lucky just sanding down will work. If not, you'll be left with the tiniest specks of rust, just these small 0.1mm specks, which you'll have a hard time removing without cutting the piece off. In that case, get the rust chemical thingy, don't know what it's called, you brush it on and leave it to dry for a few hours and the red spots become dark black and harmless. Rust free. You'll almost definatley be left with bumps and a slight hole, so filler and then sand it down. If needed, do another batch of filler, resand. once it's all flat do a few coats of primer, then paint, then clearcoat.
but eh, what the hell, it's been said time and time again eh.
Edited by MehMan
