How do you fit carbs to 16v 1.4(polo 6n engine)
How is evey 1 doin this
CIMG22571.jpg[/img]
And could you do this in 6n bay?
Also who does it all work? holla#
SteveyB 8-)
  • Replies 20
  • Views 7.6k
Hmmm where did you get that picture from?!
off here its from some meet. Fat setup innit?
i want to do it 2 ma 6n :cry: so bad?
get a manifold made for the bike carbs
get an mh code dizzy and engine loom (found on later hydro head coupe s)
remove existing inlet manifold and injection, remove ecus and engine loom
rebuild with the new parts and sort out throttle and choke linkages
buy some sort of fuel pump and fuel regulator and connect fuel lines.
Probably will be a lot harder to do if the car is a genuine valver due to the importance of the ecu and imobaliser. Most people convert AFH engines to carbs when fitting to earlier cars due to the fact it is a less complex option
Edited by mathew
The hard for me is getting it to fit in the engine bay :?
But it looks worth it :-)
It works a treat mate.
. Its a 1.4 16v on yamaha fazer 600 carbs. Goes like flip to be honest and amazingly good on fuel. Used £15 yesterday from Hull to Elsecar = 65 mls each way. Its the way forward . I used to have a 1.8 16v and it wasnt as lively as the polo engine.
MODS = ENGINE
CUSTOM GEARBOX MOUNT i.e golf and polo mount fabbed together.
POLO MK2 ignition loom and module and dizzy
POLO MK3 lift pump
LOW PRESSURE REGULATOR
CUSTOM INLET BY ME + SILICONE HOSE
8P POLO GEARBOX
MK3 POLO SUMP AND OIL PICKUP PIPE + DIPSTICK TUBE.
A TRIP TO THE OLD FAITHFUL BOGG BROS FOR A CARB SETUP.
Edited by spen
Spen i feel like find you licking your face off like puppy happy to see it owner. :-D
Thankyou for that wots bhp u reckon?
will da carbs fit in my engine bay?
i was thinking of useing gt or g40 box?
steveyB
p.s is that your engine bay which used da pic form?lol
Spen, why did you use the mk3 sump?
saw yours at elsecar spen, very nice setup you got there, i'm currently thinking about doin something similar to my mk1 golf clipper, would you recomend removing the 1.8 engine then and using a 1.4 polo?
Cheers Tom
Cheers Tom
CHEERS MATEY, If youve already got a big block engine i'd go for a KR or 9A lump on bike carbs as the engine mount on the chassis is in a gifferent place, but yeh the 1.4 16v is exellent, if you can be arsed to do the welding.
Cheers Tom
yeah that won't be a problem, it'll be worth it in the end, i think i'm going for the 1.4 block. thanks for the help. really liked your car mate, seen some trailered to shows not looking as good as yours. cheers mate.
Spen thanx for you help and takeing the time to school us about bike carbs
cars looking fat and its sum thing i am gana be into doin very soon so i am gana holla at
u
bro
You post in the engine section ....
:? there pic's
get in contact with bogg bros if you wanta proper inlet manifold making up!
spen the one you have you made yourself right?? excellent work, was having a good old nose at it at elescar!
who are these famous bogg bros? :?
company in yorkshire, just outside of york who specialise in alluminium fabrication aswell as building and prepping rally cars etc
are :idea:
you got their contacts?
stevey B thanx :roll:
Some people, so lazy!
Google Bogg Bro's and first link is: http://www.boggbros.co.uk
Sorted :-D
Renegade440'
safe mate
stevey B :-D
