Exhaust Sealent?
I can think of the propper name for this to order some to fit my new exhaust any ideas?
Jake
  • Replies 16
  • Views 1.2k
Hammerite do stuff but i'm sure it's in their Hermetite range
I think it's in a 250g or 150g tube called Exhaust Assembly paste.
You're no noob,you know better than to be posting exhaust questions in this section..
And exhaust paste is shyte - get a welder.
exhaust assembly paste, fire gum, gun gum. Lots of names for it
dont want no crap a i want the best and am not welding a £600 exhaust and manifold together!
mikey its not a technical question lol
You don't need any!!!!!!!
They're designed and built properly!
let me guess......a PPP manifold and system? :lol:
I've always used some, regardless of build quality.
Maybe on crapply built systems, powerflow and the like, there's one sleeve joint which is a tight fit, and the other joint uses a proper flange and gasket.
No need for paste on a PPP exhaust at all.
oh right, no worries hope theres no leaks:) lol should be a nice clean job
As Yoof says you shouldn't need any if you got a good exhaust system which you will have as have the same as me.
If you do have a small leak then i find using flange/gasket sealant is good. Stuff like gum gum flakes off after a while.
Edited by Robin
I'll need a bucket of the stuff then as i've got a PSD 4branch :lol:
The PPP 4 branches are going to be very similar to the PSD ones as one is being used as a set up jig for the new supplier.
*phew*
Something steve produced/designed did work right then!
smear of clear silicone sealant when it's put together if theres a pin hole leak/blow.
is that really heat proof ?
Cant tell if you are joking or not?
Wont it just melt?
i'd of thought so.
