ScrewFix welder - any good ?
Does anyone have any experience/opinions about ScrewFix's arc welder range?
Am thinking about the 160 Amp model (item 25924 from catalogue 97
http://www.screwfix.com/prods/25924/Power-...oled-Arc-Welder
for some non-structural bodywork mending, exhaust patching and
attaching a new handbrake mount.
Even with a mask and some rods it should beat the labour charges
the second time I use it.
I've not welded before but I've brazed and soldered.
Or should I save up for or hire a mig welder / pay a garage?
  • Views 3.1k
that looks like one me mate has just bought, hes never done it b4 and his reason is the same as yours go for it mate,
Crikey that does seem cheap, almost suspiciously cheap. I can't comment on their welders, Infact I don't think I would advise getting a arc welder for body work. You would probably get away with it but you really need a mig welder for what you want it for. The minute you get into welding you'll likely want to own a better than hobby standard mig welder.
I walked into my welding night class and said I'm only interested in welding cars and I was immediately put onto Mig welding. Spent the whole time learning to weld thin steel like on body work plus exhaust type tubes. I also did a bit of Tig but the kit is way more expensive.
I have a mig welder on kind of permanent lend (think it's an SIP one) which is pretty poor but I've got by with it. When I do buy one it is likely to be a Clarke one from Machine Mart around the £200 mark. They are made in the UK and everything they make has complete parts numbers and you get good parts service. Plenty of bits available too. I'm used to using the gas shroud type with the wee bottles of CO2 but you get gasless wire too which is more expensive btu good for welding outside in the wind. Machine Mart do no vat. on their Clarke stuff every quarter too if your on their mailing list. They are pretty local to me too. Think Sealey stuff is worth a look also.
Try going on a more of an Anoraks site like Practical Classics Magazine's Forum for better info.
What I really need for welding is a reactalight welding mask which cost around £70, think the sealey one is good.
Sorry for lack of clear answer, I've edited this because I only just realised it's an arc welder not mig.
Edited by MacColl
I'd save up for a MIG welder.
Actually I did. I've got a clarke 135 TE and have no complaints. Apart from the gas bottles being tiny, so I got a big one from air liquid.
I also got an auto helmet from here:
http://www.diywelding.co.uk/product_detail...3-2F6763A650AC}
The auto dark helmet makes a huge difference. Being able to see before you start an arc, and being able to use both hands to hold the torch makes everything so much easier.
Check out:
http://www.mig-welding.co.uk/
If I haven't joined-in too late, I would not advise using an arc-welder for bodywork!
During the resto of my '68 Bug my MIG died, so I borrowed an arc to finish off one last patch...
It caused more problems and blew more holes than was worth it. In the end I had to borrow another MIG to repair the damage caused by the arc!
Bought a Sealey 130 afterwards -can't fault it.
Get a 'turbo' model MIG tho, otherwise it'll really piss you off!
al you need it a mig 100amp. will do the job ;)
save up mate for a mig mate there worth it
BUT WHAT EVER YOU DO DONT BUY A SIP ONE THERE SHIT i wasted 250quid on one sold it for 50 a year later naw i have a beast i got off a mate for 180 and i spent 100 quid geting it going but it worth about 800
get a old one aff ebay you can get the parts for them easey all the same parts in most of them
