M.O.T Emissions Help
Just failed my mot on the Emissions 1998 polo 1.0L,
failed both tests on CO level and HC level
i have just used a second bottle of cataclean, the first i used about 2 months ago.
any suggestions on how to bring these Emission levels down?
any help welcome,
thanks
  • Replies 16
  • Views 1.7k
any help welcome,
thanks
new cat?
On the emissions test printout have a look at the result for lambda. If that has failed as well it means your lambda probe may be knackered rather than the cat. Does it fail at both engine speeds on the test?
i work at a test station and do these test day in day out. if its failed on co and hc then theres a few things it could be. first of all the co is carbon monoxide and the hc is unburnt petrol. i would first try the cheap and simple things before you dive in head first and go for new lambda and cat.(i have a lambda sensor you can have for free though if thats the case). but the lambda reading on the machine which it has passed, has nothing to do with the sensor really that indicates whether the car is blowing or not.
first..bang some forte fuel cleaner through it, give it a service (if you haven't already done so) and take it on a long hard run. by hard i mean thrash it. when engine is red hot take the car back to the test station and ask if they will check the emisions on a standard test for you to see if you have cured it. NOT A RETEST, just a good will check on the cat machine.
secondly.....either get the car scanned, (sometimes not nescesary) or go for a new cat and lambda ha.
anywhere near rotherham and i will put it on our machine for you
cheers
I've just bought a bosch lambda sensor for £50, i havnt put it on yet, but the one on it just about passed both tests at 1.03,
thanks for your reply and your help but i live in liverpool, miles away
G40Supercharged yes it failed both tests but the lambda passed both
just put it back through and it failed,
i put a new lambda and spark plugs in and give it a good run but the emmisions only come down a bit,
what else can i do??
thanks
Check for any leaks in the exhaust system near the cat (e.g. leaky exhaust manifold gasket). This can confuse the lambda reading and cause the ECU to set the fuelling incorrectly. Check timing is OK. Check coolant temperature sensor and thermostat are working correctly. A properly running car should get very close to passing without the cat. Post up the figures you got from the fail sheet so we can see how far out it was.
sorry if this isnt verry tecnical but boot it going up thir the high revs realy clear it out
CO LEVEL @ 2636RPM = 0.68 FAIL
HC LEVEL @ 2636RPM = 257PPM FAIL
LAMBDA @ 2636RPM = 1.03 PASS
SECOND
CO LEVEL @ 2805RPM = 0.56 FAIL
HC LEVEL @ 2805RPM = 263PPM FAIL
LAMBDA @ 2805RPM = 1.03 PASS
Is this all you need?
LOL
your MOT place does emissions testing??!?!?!?!?
LOL
what do you mean?
SECOND
CO level should be 0.30 max and HC should be 200 max. Lambda is also on the limit so I suspect something is affecting the mixture rather than it being a cat problem. Mixture has to be exactly right for the cat to do its job properly. If you have any mods (like a chip or induction kit) it might be affecting it. Check for any air leaks.
take it for a gd run 80 in fourth for a couple of miles then put it straight on the emissions tester.
if i done that it would probably explode
Edited by T-Diddy
How come people are scared of using the revs available to them? If you've never given it a thrashing then that could easily be why it's not passing the test - genuinely!
i take it they are running it through a full test specific to the car and not just a basic test. ask them if its any good on tick over, if it is put an engine cover on so they cant get to leads. sounds like it wants a good thrashing to me.
