tailgate lock will not open manually help!
I have a 1997 POLO 1.4 16V 3 DOOR MODEL BUT I AM UNABLE TO LOCK/UNLOCK THE REAR TAILGATE MANUALLY.THE LOCK IS JUST NOT TURNING AT ALL.I have tried to put lube spray in it but just has no effect. I have always used the central locking facility which works fine.I am wondering if the locks have ever been changed before albeit even the key works fine in the glove box compartment and passenger door so i am guessing not.I was thinking of replacing the lock mechanism in the tailgate lock only but unsure if it is as simple as that (i.e chip /responder in key). Any help on this would be much appreciated as it is now getting annoying
  • Views 2k
My son's Polo is the same. My guess is that the tailgate has been changed after a bump but nobody thought to swap locks. There are two solutions, first buy a secondhand barrel and key, this will let you open the boot with a key but you will have two keys on your keyring or second (and the one we have chosen) live with it! This is the cheaper, easier option as once you unlock the car via the central locking you can open the boot.
hmmm, my key wont even fit into the lock propperly, do you think any of the previous owners changed to boot?
my old polo (now my bros) has got the same problem. when it was mine i never used the boot and i think its basicly rusted up inside.
I've not sorted it yet so dont really have an answer, but I'm gonna try and get to it from the inside and see if i can un bolt it, then try and strip it down and leave it to soak in wd40 or somit to loosen it out.
thanks for your replies
I think that the barrel has become rusted up as i believe the central locking has been used only to open it. i will take it apart to find out whats going on -no signs of it ever been hit up the back -infact it all looks very original
mine was like that showed no signs of working but then i give it some serious wd40 time and then gradually kept forcing then key in then trying turn it ect. i would try persevere with it first before put a new lock in, took me bout half hour get into mine
