To do list?
Whats everyones plans for there polos?
Mine (inno particular order)
Locks!
Cherry Bomb
Corrado Seats
Gt Conversion
Decent Rubber
Fli 12" Twin Sub Box
Mountney wheel and boss.
HU with an AUX input.
Et tu?
  • Replies 31
  • Views 2.2k
sell my golf
buy a ibiza/cordy 2.0 16v
wheels
G40
in the process of getting some doors and wings sprayed
leather seats and other bits of interior
cat back
refurb wheels
fix suspension
maybe roll arches
probably in that order too.
sell the golf. :( then i will be back next year :p
LEE
mine is
buy wheel bolts to suit my alloys get tyres swapped over and fit the alloys
sell my golf
When roughly will you be looking for one?
My Cordoba 16v will be for sale soon :-) , just got to sort a few things on it first
I'm looking now mate whats up with yours?
Edited by xcore
Need to do some things for MOT - change nearside track rod and CV joint, its got a slight blow in the exhaust and it needs the ABS warning light turning off (needed new sensor). It will have 12 month MOT then
Plus I'm putting it back to standard, well except for the tarox brakes (vented, grooved discs and pads all round) and braided hoses (got robbed of 800 quid for that lot only a couple month ago by awesome gti :-(:lol: )
Should be ready to sell in a couple weeks if youre still looking :-)
Cc the door handles
Wheels
And Some 6n2 Door Cards
And i thing that will do 4 me
Edited by Po*Low*
Lower the front
fit GT cam
New doors
Gt exhaust system
1.0 chip
1.3 throttle body
refurb the wheels
sort the rear quarter out.
Sell/gt it
sell.
Car is a MK3 1.0 Genesis, most of the way through a GT conversion so,
Probably in order,
Finish off GT conversion
Remove centre box from exhaust
Finish de trimming sides (ripped plastic bits off, still to get the glue and shite off)
Fit 40mm lower springs (roads are terrible round my way so dont want to go lower)
Fit Polly bushes
Fit a good back bumper
Nice wheels, poss 7x13 ATS Classics
Get better rust free doors
Respray next year
Going to see how the GT goes but may go for some mods like a fourbranch, chip and cam.
i need £600 worth of parts, not including the subframe i want.
polish my g40, sell it
put my spare eaton g40 in another shell. drive it.
this weekend:
wrap turbo downpipe
get some pipe for water supply & return to/from turbo
weld a take off for water supply onto metal pipe on top rad hose
connect up water pipes
fit downpipe and connect exhaust
put oil filter on, put oil in, put coolant in
get turbo conversion running
drink beer
the GT:
fit reconditioned rear beam, camber shims and roll (maybe flair) rear arches, lowering topcaps, new front tyres, upgraded brakes, good service, fit 12" steering wheel, 4branch
the square:
fit the 1.3, G40 exhaust, a few straight panel replacements, new front bumber, bodge on induction kit with golf arm
i think thats it, more crops up everytime i think though :D
buy a shed of a 6n
strip it
cut the boot floor out
mount either a bike engine or big block vw lump in the boot.
rebuild shell
rag it
then probably sell it!
Quite a few mods to come:
Lower on coilovers to replace 30mm springs
Alloy Wheels and tyres
Fit cental locking
New seats front and back leather
Sub and more speakers
Edited by BVW
Still to fit
Stuff purchased
Silver Decals
Fuel Pump
Borbets
Coilovers
Magnex 4 Branch
Exhaust Manifold Flange
Gearbox
Lower Shift Rod Bush
Engine Rebuild
Clean & Paint Engine
Head Gasket
Audi TB
Starter Motor
Time Engine (TDC )
CO Setting (1-2%)
Idle Setting (950 rpm)
Coolant System
Water Pump
Hoses
Injection System
***New Injectors
***Fuel Filler Neck Stainless
*** Fuel Tank
Body
Front Badge
Fit Green Screen Glass in Bootlid
Fit Badges to new Bootlid
Fit Silver Side Decals
Tint Reverse Lights Red
Tint Rear Indi's Black
Tint Front Indi's Black
Stereo
*** Component Speakers
*** Subwoofer
*** Amp
Brake Eventual
Audi 256mm Conversion
Braided Hoses
16v MC & Servo
Chrome Brake Linkage
*** Dot 5.1 Fluid
*** Collect Rear Axle
Welding
***Front Lower Valance
***Rear Panel
Passenger Sill
Drivers Rear Arch
Sunroof Plate
Stuff to Buy
Thermostat & Seal 17626/17961
Coolant
Coolant Hoses
17984 (£5)
18000 (£5)
17920 (£4)
17953R (£4)
Headbolts x 8 01161 ( £1)
Ball Joint x 2 42441 (£9)
Wishbones x 2 42215 (£17)
*** Hub Housings
Polybushes
Injectors
Stainless Filler Neck
Fuel Tank
Bootlid
Pressed Plates
Front & Rear Lower Valance
Drivers Sill
Parts Done Already
126k
GSF Shift Linkage Repair Kit
MissingLinkz Short Shift Kit
15x7 Lorbers
Oil Filter
Oil Change
Coolant Change
Tracking
Magnex SS Exhaust
TSR SS 4 Branch
Corbeau Reclining Bucket Seats
Single Wiper
Fuel Pump Relay 93590 19.80
Plugs SB95015 x 4 5.00
Air Filter MMC2860 6.50
Leads 92630A
Top Radiator Cover
Remove Brake Light
Fuse box Wiring
Rust Por-15'd
Removed Ariel
Blanking Grommet for Ariel
Blanking Grommet for Wiper
Clutch Cable
Throttle Cable
Throttle Pedal Teflon Bush
127K - 06/03/2009
(2k) - 12/03/2009
Earth wire for alternator
Static Timing Set
Fuel Pump Cut Off Switch
New Green Tint Screen - 18/03
Replaced Bonnet - 18/03
False Floor Fitted - 18/03
128K - 20/03/2009
Gearbox oil
Lithium Grease on Gear linkage
128339 (3k) - 25/03/2009
Rotor Arm - 26/03/2009
CO Checked - Fine
Armoured Door Plates 29/03/2009
Fuel Filter 29/03/2009
New Battery 29/03/2009
Coil Wiring to Fuel Pump Relay 29/03/2009
TSR Airbox - 30/03/2009
K&N Panel Filter - 30/03/2009
TB Gasket Kellogs - 01/03/2009
129k - 03/04/2009
New Oil Pump
New Oil Filter
15w/40 oil
New Rocker Cover Gasket
New Sump Gasket
Baffled Ali Sump & Gasket
New Screen Wash Pump
New Radiator Cap
Leather Interior
New Alternator Belt
129339 (3k) - 06/04/2009
130k - 13/04/2009
Mk2 Golf 16v TB Gasket 037 133 073A - 13/04/2009
This weeks list
18-19/04/2009
Black Diamond Discs
Pagid Pads
Fit Coilies
Fit Wheels
Fit exhaust manifold
Tap and die head
New Cam Belt
New Cam Belt Tensioner
Cam Belt Cover
Inlet Manifold
Timing
Fuel Pump
Remove Fog Light
:lol:
ps i love microsoft onenote
Fucking hell Saf :lol:
8-)
Edited by D16RRT
Daily Valver:
Lower it more,
Remove bump strips,
Remove rear wiper,
Fix front bumper,
Fix drivers seat,
Fix sill.
G40:
Get it running
Other valver:
Sell it.
Mk3 Genesis:
Fit old AFH engine.
Edited by kwijibo_coupe
Find a set of lowered shocks that aren't rock hard and will suit relatively soft 60mm springs.
Build a new exhaust,and find a valver tubular manifold for it.
Cable-tie the wiring again (properly) behind the fuse box,as it keeps pushing the trim into the glovebox.
Change to a modern design of bonnet hinges so i can fit a bigger battery without it being in the boot.
Re-fit the rear lap belt and find an insurance company that actually recognise that its a 5-seater,not 4..
Sort the rear wiper out,so it parks horizontally instead of vertically.
Fit a new front bumper,replacing the now slightly pissed item,since being nudged in a car park by some vacant skulled corpse.
Ditch the patterned-flock window surround detailing and side stripes with stuff of the correct texture.
Find a fifth Hockenheim wheel to use as a spare.
fecking hell Saf mate, you're using up all the bandwith! :lol:
The G...
run engine in (carefully)
things to buy:
front disks & pads
braided hoses
bigger m/c
hnr suspension kit
PPP subframe
LSD
Nos
several sets of front tyres
custom rollcage
race fuel tank
polycarb windows
The mk4:
give it a service
Things to buy:
coilovers
better wheels
10" sub
whatever else Rach wants for it!
The bready:
new battery
sort out seized hub on back
put it through MOT
get it taxed
spray it matt black
pay Charlie to do some of her awesome artwork on it.
use it to pimp to work and back.
Think Saf wins with Jon a close 2nd :lol:
Polo
Swap springs and dampers for coilies
Get drivers door and wing sprayed (maybe bumpers as well)
Get cracking on some interior styling
Get some dished multispoke loveliness for wheels or something rare
New front brakes
Scirocco
Put coilies on (currently sitting in my hallway)
Get it running reet
Finish the wheels I've got for it (stripping and polishing)
Edited by jonPDpolo
In no particular order:
Respray
New interior
Remove bump strips
Wheels
Chop a coil or 2 off the springs :badgrin:
Bike carbs or GT conversion
Get bored of driving a GT and get a G40 conversion
Eaton charger for said G40 conversion
Edited by Sian-Marie
