mk2 polo bits
i broke up a mk2 polo 1.0ltr breadvan a while back but still have lots of bits left
1.0 radiater SOLD
fan shroud £7
full wireing loom inc fuse box,fuses and relays £15
front and rear wiper arms £2 each
door seals £4 each
interior door handles,winder handles etc from the doors £misc
window regulaters £10 each
front q-lights £5 each
ignition module and coil £15 for both
distributer with vacum £10
front seat belts £15 the pair
all engine mounts £10 each
starter £10
radiater fan £10
expansion bottle £6
ashtray and heater surround £8
clocks with 58k(non rev) SOLD
clocks surround £5
heater controls from inside the dash £5
1 rear bulb holder £3
fuel tank (nearly new) £25
fuel tank sender unit floor cover £3
rear and front shocks covers(round plastic bits) £1 each
horn £2
horn push from middle of steering wheel £3
interior mirror SOLD
handbrake lever £7
4 speed gear linkeage £15
standard grille SOLD
exhaust manifold heat riser plate £5
water hoses SOLD
down pipe clamp £2
a bag of tiny trim bits,bolts,rubber bits,plastic bits ask and i will check if its there
can post everything,what u needing!!!!!!!!!!
Edited by low bay
  • Replies 29
  • Views 981
discovered more stuff i need!
Have you got the plastic rear arch spats with all the mounting lugs intact? a couple of my tabs are snapped so want to try and source a good pair before i resort to the double sided tape.
price including postage please if they're in good nick
cheers
mack
haven't got them sorry
Do you have Door cards?
Regards,
Chap, I could do with the pipe from the back of the engine that all the pipework for the cooling runs through. Also all the hoses as mine have more pipework in the hoses than metal on the pipes. Price for all posted? Cheers
i take it you mean the metal pipe that comes off the water pump that runs below the inlet manifold? and all the rubber hoses in the engine bay or just the ones from that pipe?
Regards,
no door cards sorry
Yep thats it me old son with all the hoses. Any chance?
the metal pipe and all the hoses i have £20 posted
Sold! You have a PM
still have the distributor? how much posted?
all still avaible
where are you absed mate? intrested in the clocks if you still have them
ash
up
what are the clocks like
perfect working order with 58k on them,all clips etc intact
clocks sold
alright m8 u still go parcal shelf and the ram that opens the boot if so m8 how much ?
Thanks Hooper
Edited by htidhooper
do you have the jets washers off the bonnet for a mk2 bonnet
clocks are great cheers
no parcel shelf,may have boot rams
will check the bag of bits for jets
Do you have the rubbers for the driver and passenger side window?
on the door or the rear quarter?
if doors i think i do
On the door
alrite mate do you have a set of stearing arm's if so how much posted cheers
