Removing door cards
well my passenger window decided to pack up the other night, had the window down, went to put it up, moved an inch then it stopped and decided to drop into the door. not sure whether its the motor or other part of the mechanism.
so, how do you remove the door cards in a mk4 16V?
Matt
  • Views 1.8k
There's 2 Bolts in the handle take them out then everything else pops of , it needs a hard grip to get them off but also be careful :)
unscrew the door pin too!!
Blimey!
Do that to ! :paranoid:
does the door pin just unscrew then?
Yes it does
all done and dusted now,
door card was simple enough, one of the clips on the runners for the window had broke hence why the window had dropped the other night,
just done a temporary fix for now using the bit of the broken clip that fits on the runner and cable ties 8-) lol
Haha been into my door so many times to fix this :S, ended up putting screws into the ends but even then it breaks occasionally :(
