polo n6 small build
hi all just moved this over from the blog section coz i realy aint got a clue what to do with the blog thingy lol
i have taken on a new little project as the sierra has gone :(
this is going to be an ongoing project so will keep you updated as i get on with it
so i managed to grab hold of this little vw polo 1.4 , i have always wanted to have one of these to play with and this will also take some of the millage off the audi which has now reached 115k so i need something back and for to work which is cheap .
so here she is
have had a set of 14" steel wheels for her so far which i gave a lick of paint to last night they came to me like this
so started first just cleaning whith acid free wheel cleaner to get the worst off
then it was onto the flating back with 180 grit wet and dry
so before sanding
only sanded lightly
then on with high build primer
painted the centre of the wheels with satin black
then after a while to dry infront of the heat lamp masked up the centre to spray the edge silver
with the centre caps i sanded the vw in the centre and touched in with a black touch up pen which left me with this
i was well happy with this reult and its exactly the look i was hoping to get :)
so i orderd a new set of boots i oppted for 165/60r14 i was hoping to get a more stretched look but couldnt realy determin what size to go for but i am happy with the way they sit for now :)
tyres were fitted by my mate and myself (seejayats on here )
i knew my ten years of tyre fitting would be usefull lmao
so this is a before and after time
so they are on and its mot time tomorrow :)
i have already got the clear indicators for the front and the side repetors
and the badgless grill is on its way !
the coilovers have been ordered to so she will be sitting on her backside very soon :) they are capable of being lowered from 20mm to 120mm so it should be enuf :lol::lol::lol:
as for the detail it will be having the full treatment over the next couple of nights after work but i will keep you updated
ok got the car home tonight and started the detail ththis is what the car looked like at the start :)
the paint is pretty shocking tbh ! so with a bit of luck the weather will hold off for the bank holiday and i can get it corrected
but at least the washing and the claying has been done :)
process
AG apc all the car working in with a brush
then rinced
onto the snowfoam
while the snowfoam was dwelling i worked on the door shuts and the doors with AG apc and the brush
couple of befores during and afters
car was then rinced shuts and exterior and then i washed the car with MEGS gold glass shampoo
and left me with this
onto the clay and i used megs clay and megs last touch as lube
this was half of the roof n/s
boot lid
bonnet
car wash the rewashed using the same process as earlier and then dried with a sonus wun der drying towel
so i decided to put the clear indicators as the light was starting go and i couldnt wait any longer :lol:
the new ones
as you can see i was missing the gold fish from my indicator :lol::lol:
while they were out i apc the side of the head lamp and the indicator seating
after they were in it was onto the badgeless grill ! the standard grill however aint gonna be going back on as some of the clips snap as i removed it with a little force coz the clip holders were a little rusty ! but she came off in the end :)
the new grilll and fitted :)
and it made a hell of a difference to the face of the car fair play :)
just cant wait to get the coilovers on now and get it SLAMMED
had a day off today so i thought i would get on with some polishing work ,
but i first had a little look at the side trim to see if i would be able to remove it ! on inspection (as it is hanging off a bit) i could see behind that the door at sometime has had a little paint .
but whoever painted the door was to lazy to take the remaining trim tape off and just painted over it ! where it is marked you can see :(
so this is gonna stay on for now dont realy want to spend money on painting the car as it is supposed to be a runabout :) ( it will prob be done very soon knowing my ocd:lol:)
anyway onto the paintwork
using my silverline and AG polishing pad oppted for paint renovator with to passes and then one pass of AG 02B fine renovator ,and then one pass with good old AG srp
good old towel under the bonnet to lift it not to catch the wings
a reflection shot with the sun tring its hardest the get through the clouds and failing
after two passes of AG paint renovator and a shot in the process
and after a pass of AG ultrafine renovator :):) perfect
after that i did one pass with AG srp just to make sure
before and after with led tourch
so that was the bonnet corrected and onto the o/s wing using the same proccess as before a couple of befores and afters
50/50
and then the back of the wing
and then some horrible looking clouds were lurking and then the inevitable the heavens opened so rain stops play for now :(
will keep you posted when i get another day on the polishing
  • Replies 27
  • Views 5.6k
Looks nice and clean does that.
Still has the legendary dent on the bottom of the rear bumper whicih every 8v seems to come with!
it amazes me how this 'paint correction/detailing' process can really make a car get back to it's former glory! I also like your style with the mk4, low and simple!
Looks Like a good base to start from. Think is will look x10 better when its slammed 8-)
jesus christ thats awsome! hats off too you fella!
i like, what a diference it makes when cleand/polished. looks like new paint :) nice 1 and 100% on effort, bring on the lowness..
LEE
thanks guy:)
well the sun came back out so out again with the gear and carried on with the correction
seeing the door trim aint coming off just yet they got masked up
50/50 of o/s door
corrected
rear os wing
pillar o/s
the boot lid o/s side
and two reflection shots
well chuffed with the bonnet :) thank for looking
good work.....very good work.
get some coilovers and its a winner
they are sitting in the front room in a box :) cant wait to get them on :)
Really really good paint corrextion there mate ..
What products / mop did you use ??
what a great thread mate, the car looks new lol, sorry for sounding like a noob but what are you duing with that paint brush thingy lol, what does it do, and where do you buy the snow foam stuff ? thanks
Josh
wow the detailing skills are immense, fancy doing my mk1?? and i will fit your coilovers??
but loooks fantastic, nice job so far
Exactly what i was thinking mate.
silverline polisher
auto glym medium polishing pad
auto glym paint renovator
auto glym 02b fine paint renovator
auto glym super resin polish
megs last touch detailer to prime the polishing pad
scotch masking tape :thumbsup:
lol do you mean in the door shuts ?? if so i use that brush to work the apc (all perpose cleaner) in to get the stubborn dirt moved :)
cars looking fantastic! loving the cleaning thread! will look awesome once its been decked! good work!!!
first off i would like to give a "big up " to ANTWAN thank you so much for coming up to give me a hand fitting the coilovers on the polo (tbh he did dam near all of it ) you are a legend :thumb::thumb::thumb:
so off with the wheels and sraped up all the bolts to be removed
and it wasnt long before antwan had the strut off
new coilover you can see a big difference in the size of the legs
top mount
to be safe first off we set the coilover at 40mm from the bottom of the thread
once the coily was fitted in the turet you can see where the old shock left the hub sitting !! little bit of a differance lol
once fitted i sprayed the coily with ACF50 (anti coprrsion formula 50 )
to give it a bit of protection from the elements
before re fitting the wheel we took the arch liners out just in case they were going to rub
whell back on the fronts fitted :)
onto the rears
again a hell of a differance in length between the two
also lowerd the spring 40mm from the bottom again
how close is the bolt from the inner arch lol
and refitted
after dropping the car down and going for a spin around the block
we decided to take it down further so the fronts went down another 15mm
and the backs a further 10mm
so a pic of before
and after
a little different from the start of the project
hope you like :) i am well stoked cant wait to get the clear side in repeaters now :)[/
and a little vid of how she looks on the road :thumb:
both antwan and myself think that the ride is awsome not to stiff just nice
th_2008_0507blackyskyline22230028.jpg[/
i like it alot mate, it actually looks 10x better from when you first bought it, what a difference some coilies, grill and clear indicators do! and nice and cleann!! keep it up mate :-D,, want mine to look that clean haha
looks brilliant mate soooo much better than before,
was a good read too :thumbsup:
keep up the good work top detailling skills
thanks fellas :) willl be carring on with the rest of the detail as soon as we get more nice weather
and when the garden aint taking up my time (having a garage built )
adn off to the nurburgring this coming weekend so it will be on hold for a week prob ,
fitting the new yellow stuff pads for the ring trip on the audi and a mini service
could go lower! :p
looks top mate :thumbsup:
you an amazing detailer! and i love your before and after shots :thumbsup: i think you need to space the wheels out some though!
thanks for all your comments folks :)
wow awesome!
Cant beat a good detailing, youve done an awesoem job :D
thanks matey been doing it for aabout a year now :) loads of threads on detailngworld lol
could go lower! :p
was thinking the same matey gonna leave it settle for a week and then see how much more it can go
but have come across a very cheap subtle body kit to so we will see :)
the spacers will be ordered when i get back from the nurburgring on tuesday :)
Edited by hawkey
looks fantastic! awesome lil ride! very impressed with the detailing work! getting me in the mood to go proper mad and clean mine properly rather taking shortcuts!
really interesting thread!! Keep it up mate!! Finish it off with some nice wheels and you have a winner!!! :thumbsup: :thumbsup:
