please help me i need this asap
can i use the bolts for steel wheels on alloy wheels as a tempory measure till i get sum proper ones at weekend?
Edited by tompeters
  • Replies 13
  • Views 1.7k
not ideally
they can shear, if there say, domed, and the alloy ones require cone shaped
i wouldn't risk it
they are domed i think they are gti wheels off a 6n2 .
any help they fit properly i am not going to be going far??????
cum on peeps i need to know this asap
wouldnt risk it tbh. I did and fooked a hub up in the process
i didnt know you could get different bolts for alloys. i have been using the old steel ones for years, never had a problem.
oh dear, in such a noobie. :(
it depends on the alloy wheels. Most aftermarket ones have tapered seats whereas steels will have radius seats. But some alloys have radius seats too, esp if they were factory fit alloys originally.
if they are polo gti rims, they should be radius seat, and so long as a good amount of thread pokes through, you should be ok with the std bolts.
if you get one of your bolts and place it in the gti wheel bolt hole, it should sit in the hole nice and snug, if it doesnt, then its like the hole is tapered rather than radiused, and therefore you will need new tapered bolts. do not under any circumstance use the wrong bolts, it will end in tears
cheers for this lads ill check soon n post up
Snap! no children were harmed in the making of my noobism with wheel bolts
As long as they tighten up tight and dont come loose, i thought that was fine????
so i should be ok for now lol
I asked this a while back and everyone said they would be the same....
I have some BBS RA 15" to go on my polo shortly....they were from a golf so VW wheels... but will they be tapered or radius holes? and what are the standard mk4 polo 13" steel bolts?
BASICALLY do i need new bolts? lol
i just stick any nuts in the have the right kind of length thread, mix and match most of the time too, never lost a wheel yet... well one but i think some little shit undone that for me as i doubt the wrong kind of nut makes all four undo themselves over night :disgust:
Edited by McLOVIN
