g40 bottom end - melted piston + more
got a g40 bottom end, covered under 80k but a blocked injector led to a melted piston. still has bottom pulleys, water pump, sump, flywheel and clutch attatched.
got a few other bits, lambda pair of g40 manifolds - £25 each delivered i'll see what else i got.
block is collection only from bracknell - sensible offers accepted.
thanks, olly - 07789 18 48 58
Edited by polo6n2g40
  • Replies 21
  • Views 449
what conditions the lambda probe in ? Could do with a spare until i can afford VW prices for a new one.
i'll dig it out and have a look. iirc it was fine.
i may have a head and gearbox too though i'm not sure yet.
if you got a atv box might take it off you
got a charger in pieces, not uprated at all, been laying in the shed for months - it should all be there, in what condition anymore god knows.
again sensible offers.
i think the block is sold just waiting on confirmation.
i did have from the same car 80k but not sure what happened to it.
I may be interested in the head mate. Want one for a BVH :unibrow:
ah i see, i'll have to see if i can find it. make an offer and i might spur me on....
gotta see what cash flow is like yet. i think Phil will want a wedge of my wages when i get paid :-(
no worries mr loctite. i'll pm you when / if i can find it along with pics.
:roll:
right none of this lot has shifted,
bottom end - had a closer look - bores are surface rusted £80 collected
charger can only find two half casings, scroll and shaft £60 collected
g40 pwo fpr - offers - may post
co pot - untouched - offers - may post
g40 - g60 injector chip - offers - may post
jon i found the lambda it's not genuine but direct fit, and was working perfectly when i removed it. pm me and we'll sort a pricey.
still have 6n grill and surround free to collector
6n + 6n2 mpi fuel pump £15 collected
and 6n2 gti centre console + ashtray
6n2 and 6n power steering rack pwo very clean £25 collected
boot carpet
rear plastic trim in boot with cut out for changer
cd changer bracket from 6n2 gti - all free to collector.
boot carpet
Have you by any chance got a drivers side engine mount please? What sort of condition is the charger in,any chunks missing or obvious damage at all? If it's apparently undamaged I'll have it off you! Thank's ,Peter. :-)
Hi mate,
Do you still have the full cam cover for the g40 engine? Also I need that little thing that it bolted onto the block near the bottom pulley that is used to time up that pulley. Its like a T shape bolted on with 2 10mm bolts, do you still have this?? Really need one.
Also do you have a pic of the co pot?
boot carpet
think i sold the mounts, i've got to provide pics to a potential buyer for the charger, if it's not what he's looking for then it'll be up for grabs.
Hi mate,
i'll get a pic tonight but won't be able to post it for a while, unless you have a number i'll text it to you. don't think i've got a rocker cover. the timing mark is still bolted on the bottom end.
Hi mate,
yeah sure, if you clear out a bit of room in your inbox ill send you my number. Sorry, I meant the cam belt cover, not the rocker cover. My bad didnt explain it properly. Cool, if you have the cambelt cover ill have both that and the timing mark off you.
i'll have a look around, inbox space cleared.
got a service book / owners manual from my 98 16v 6n - offers
complete steering column with ignition + key + immob box for chipped key from same car
£20 collected
Dont suppose you have got the inline fuel pump that sits behind the drivers side rear wheel have you matey?
If so, how much inc delivery please?
g40? i sold two pairs of pumps recently for g40 for £40 a pair.
boot carpet
No problem,I've sourced a mount now,but still up for the charger if sale does'nt work out...I'm local (Guildford) so collection not a problem.Peter
