Whats goin on with these locks?
Right, i didnt mind at first, but its starting to get annoying now.
Basically, it looks like someone has tried breaking into the car at some point in the past.
The drivers lock has been replaced with a completely different lock to the rest of the car. The key isn`t square, its kind of normal, and i can only open the car from the drivers lock. The boot key opens the boot, but its a little stiff. The original key in the passenger door does nothing at all, but is used in the ignition as normal.
Why have they done that? Was it a case of 'it was cheaper than getting it sorted properly'?
Ultimately, what i want to know is;
1. How expensive will it be to get the drivers lock replaced so i can use the original key.
and/or
2. What could be the reason the passenger one does nothing and can i sort it?
or
3. How expensive would it be to get a whole cars worth of new locks (from scrappies or off here) and how much
of a ball ache is it to fit them all?
Cheers :)
  • Views 972
Well i think i figured out why my passenger lock doesn`t work today.
The paddle has fallen off and was the cause of the 'rattle' when you shut the door :)
well i dont know if they use the same system as my dad bmw's pannier but he just pulled the lock barrels out and then played with the "Wafers" till the new key worked but i dont know if this would work for the door locks though!
i could ask him for the guide he used if you like though.
stix
door locks are pretty simple to change, once you done 1 side, the other will be easier.
boot i haven't got a clue about, I doubt the ignition should be too hard, as long as you have some mechanical knowledge I think you'll be fine.
stix
lol thanks, but i dont think i`ll be messing with any 'wafers'.
Yeh i have some mechanical knowledge. As long as theres no niggles with changing them, i should be ok. It was more the cost of a full set of locks (front doors, ignition and boot)
If was going to find a donor car, i wouldn`t mind ripping off the drivers and passenger glove boxes with locks while i was at it lol
my key doesn't even fit in my boot so i cant open it that way :( lol
