Electric window regulator clips
Hi,
I have had problems with the plastic runners on 6N Polo electric window regulators recently. The plastic clips on the runners break, causing the window-support clamps to work free and the window to jam. A quick look round the forums made me aware that I was not alone!
The accepted solution is to replace the entire regulator assembly. However, I found the aftermarket regulators to be very poor quality, and the genuine ones are expensive. In the end, I solved this problem with nothing more than some 6mm bolts and 12mm nuts.
After removing the regulator assembly from the car, I carefully trimmed the remains of the plastic clip-parts away, leaving a square "post" on the runner which locates the steel window-support clamp. I then mounted the steel support-clamp in position, and screwed a thin 12mm-thread nut down the outside of the plastic post, to act as a spacer and to give the post some support. This nut must be tight (it forms its own thread on the corners of the post). You may find a slightly different sized nut works best. Alternatively, you can use a small piece of steel tubing, no more than 8mm long, and tapped firmly into place.
Finally, I screwed a thin-headed M6 x 20 bolt (with a thin flat washer) directly into the hole in the middle of the plastic "post". This simply formed its own thread in the hole. I also used some Loctite to help to secure the bolt.
The key to this technique is to ensure that the plastic post is supported tightly on the outside by the nut, otherwise it will split. Note also that the steel window-support clamp should be free to float slightly on the runner-post.
The reason for all this emphasis on thinness will become apparent when you mount the regulator back in the car. The runners have very little clearance as they move past some strengthening beams on the inside of the door skin. However, you should find that they have 2-3mm. If they do jam, it will be on the way down (at least you won't be left stranded with an insecure car). They can be released by distorting things a little once the inner trim is removed!
Jon Gathercole
  • Views 949
Thanks for the help mine has just stopped working lol
How did you get the innards out of the door I've unbolted everything and got the runners loose but cant seem to get the window down or anything out.
Thanks Dazza
