first time polo owner
hello
just need some help the polo i bought from my uncle an r reg 1.4 cl , the central locking doesnt work and there water getting in the passenger can anyone help?
  • Replies 9
  • Views 1.3k
hello
The central locking could be the fuse has blown for the central locking in the fusebox or the central locking pump has broke.
Water in the passenger footwell i guess. Front or rear? Try a forum search, there are many places it could come in. Blocked heater matrix is 1 door card another common 1
thanks
he said he popped open the petrol cap aswell how do i fix that?
thanks
You mean the petrol cap won't lock?
if its leaking into the rear passenger side then it could be the rear washer bottle pipe that runs under the carpet. Easy fix is to remove the pump front the bottle and de wiper it
its a 3 door leaking into front passenger
and yeah he said he got a screwdriver and pulled open the petrol cap
You need to go to the boot, and pull back the carpet where the first aid is. Then remove the central locking pump and put your hand down the side of the car. Feel for a metal rod and push it to the petrol cap. When you do this you need to do the same thing to unlock it when you fill up with petrol.
i had the same problem with mine with the footwell fillin up it was my heater matrix, i just bypast the pipe on the bulkhead. no heaters now but thers no water lol
tell the passenger to stop drinking.
