Superflex TCA bushes
As above really
Finally found the cash to lower the car, and I'm changing a few bits whilst I'm at it.
So, I'm looking at getting the bushes for the TCA from superflex (as they are cheaper). But is the lower price reflected in the quality? or do they do a good enough job?
http://www.superflex.co.uk/results.php?mak...4&Search=Go
Also, it has different diameters for the anti roll bar bushes? What's the correct one for a 93 MK3?
Cheers in advance, Toby
PS, sorry if this should be in the suspension section, wasn't sure.
i used them on a road g40 for a few years and i rated them... esp as they weren't toooo hard
The ARB is 18mm - i dont know where they got the bigger sizes from but id be interested to find out!
You'd need a serious rear ARB to compliment a 24mm front item..
Personally,with the compound,id go for 70s on the TCA-ARB and 90s on the TCA-inners. This is considering i have solid front ARB mounts though - if you're going for poly front ARB mounts,you want 95s on there.
Or better still,G-laderseite nylon blocks.
And i think i will - I've never considered Superflex to be budget level,and despite usually going for 'off the shelf' parts (and thus have no experience with poly) I'm going to order some.
