Boot Popper (solenoid)
has anyone got one how did you wire yours in? do you need to take a live from the wiper feed? :-D
  • Replies 10
  • Views 1.4k
i'd also like to know this, also maybe a guide if anyone knows of one :)?
edit: spellings
Edited by Stonez
bump
i've got a boot solenoid in the bootlid outside if you need pics?
I'd wire it to one of those push buttons (available from halfrauds or any moto factor) and put it on a blank on the dash.
Some people do wire it to the rear wiper so when the stalk is pushed forward, the boot releases. Would be ok until you knocked it driving down the road :lol:
:lol: good point hmmm what else could i take i live from then inside the boot any recommendations?
i used a mk4 golf fuel flap solenoid and wired it into the rear wiper wiring.
Never had an issue with it.
Best thing to do is get a seperate little blank button, and then put it into one of the dash blanks.
Just run the wire in the same way you would run it to the front of the car to wire up an amp?
i'd use a new feed too as you wouldnt wanna risk overloading anything. There maybe a spare fuse location in your fuse box. I'd use that and then stick in an appropriate fuse.
x2 Thats what i've done on mine.
I just used a spare pump thingy i had from an rclick set. So now my boot pops open when i hit the button on the key fob.
