Polo 6n Wiper Blank
Just had a look on justmatz for a new wiper blank (mind fell off down some back roads) and it now says (Polo 6N are now obsolete)
So any ideas where i can find one?
Cheers guys
Andy
  • Replies 17
  • Views 2.4k
you can get these from halfords, I'm not sure if all halfords have the same layout but i mine was in the electirical section, make sure you get the 25mm one, its just one in a packet
(there is also a pack with a set of 3 but biggest one is 24mm and thats too small.)
Hope this helps
6n and 6n2 are diff sizes mate as i found out when put gti lid on mine yesterday
oooerr...
well i still recomend getting the biggest as oversized is the way to go. when i had 24mm it was like a perfect fit, and the chavs would come round and poke to bloody thing thru so i had to take the cover off the inside of the tailgate, get it out and put it back in -.-
even if it doesnt fit its only £1.50 hardly breaks the bank =/
Cheers for the reply, but the 6n2 has a different rear window which doesnt have a recess cut out for the wiper, am looking for something like this:
ohhh, I'm sorry then mate i dont know. Let me know if you do find out could be usefull in the future, best of luck :)
you tried eBay?
Hope this helps
does the 25mm fit it tight on 6n2 mate? as i got some dodgey plastic thing in there at mo with a 2p glue on for decoration :lol:
People have made their own ones before
Use the existing piece of plastic, fill the hole, then paint, shouldn't take too long to do
Thanks for the reply, but i tried that, stuck it on, and it fell off lol, cant find it anywhere, think i used the wrong type of glue
These are good blanking plates that also looks good.
how do these stick to the car? as mine fell off aswel but want one that sticks to the hole not the window
put a bung in it first, then put a plate over the top, looks smoooth :D
i turned mine on a lathe at work from stainless steel , its worth about £140 lol medical grade stainless, then i sprayed it black and used the original rubber seal and bunged it in , lavley job .
www.venommotorsport.com
Hope this helps... :)
alright mate i had the same problem yesterday, i phoned up just matz cause vemon dont do them either and the bloke from just matz has just got a set in but the not plastic they are flush glass so will look better.. i paid roughly £25 delivered. hope this helps
Edited by Azza B5.5
the ones from venom DO NOT fit 6ns they are a small round peice of (really rubbish quality) glass for 6n2s etc the easyest way to do a 6n blank is make one from the old bit of plastic left over from the wiper assembly bit of silicone in the hole in the car then fill the plastic and spray, mine is stuck to my car witgh black silicone but my bros is held on with foam double sided pads. hope THIS helps :grin:
