Problems while I've been preping my
Hi as I've not found any dragon green 16v bumpers i thought it was time i started to prep my silver ones ready for a lick of draon green. Problem is I've started to sand down the bumpers and have come across some realy deep gashes and stone chips. I'm just wondering how i can tackle the scuffs/chips? filler? fibreglass? resin?
  • Views 1.3k
fill them ? common sence really.
fill them... the clue is in the name!
Use some p38 isopon filler no need for resin unless your filling one of the grill slots etc. Just wack it on, let it dry and sand down starting with prob 320 wet and dry going finer grit up to like 800 then have a look for little pin holes and maybe go over another time repeating the process.
Thanks used p38 and got a lovely finish once sanded
Nice one mate if you find youve got any tiny little pinholes or sand paper scuffs you can get some ultra fine filler or glazing gel using a really fine layer or two and use some 1000 or 1500 grit should do the trick.
Thanks for the advice mate but I've already sorted the small pin holes using stopper then rubbing that back with a 1500 wet and dry.
Just got to put it in primer now then get hold of 1L of dragon green.
