6n2 Hand Brake On a 6N
Will A 6N2 hand brake fit my 6n
I did try and search 4 it but did not find any think
  • Views 917
its fits right in no bother. uses same points to bolt down etc :)
only prob is the surround wont fit back on so yu will either have to cut and shut your original one or find another one that may fit :) still to work out what to do with my own :)
So it fit right on no probs then as I'm just about to buy 1 if it fits with no mods
My surround if F**ked any way lol
Edited by Po*Low*
yep i fitted rachels handbrake :lol:
had to undo the cable a bit if i remember rightly but other than that its all good :)
i think a wee cut and shut on your trim would be fine :) its because of the plastic handbrake gaitor is a differant shape :)
Ahhh thanks
Is it a quick job
takes all of 5 minutes :)
couple bolts hold it in place. take off put on :) hardest part is adjusting the cable but even thats a piece of poo ;)
