Buying a polo MK3
Hello, i'm new here and buying a polo, i own a scirocco pretty clued up on cars but just wondering if theres anything particular that could go on a MK3 polo GT? Going to view one tomorrow just need to know if theres anything to look out for? Any particular rust spots? common faults (head gaskets, cooling issues, anything like that)? any help would be great!
  • Views 855
Howdo & welcome.
Mk3s tend to rust along the bottom of the doors, wheelarches (behind the plastic arches if its a GT/G40) and on the bootlid around the glass.
Engine wise, check cambelt side of headgasket and sump gasket for oil leaks.
Howdo & welcome.
Cool, thanks for that, just the type of info i was after!
Howdo & welcome.
Also fuel filler neck where it meets the tank and the battery tray (stick your head under the dash at the steering wheel with a torch and look up)
Be sure to stick up some photos when if you buy it :-)
Howdo & welcome.
Coolio, thanks, seem to rememeber the rocco had problems with the fuel filler neck because the rubber corrodes, i'll defo get some pics up if i do (no doubt i will, very much in need of a new car, current daily is crippleing me :( )
