tailgate lock /handle
bought a new tailgate today to replace my old dinted one the problem i have is i cant get the lock out to replace it with the one off my car? i have removed the 3 star bolts that hold it in but the handle seems to be too big ta come out? i haven't got central locking so i can't leave it in it has to be changed , can anyone help me please??????
  • Replies 11
  • Views 1.5k
does anyone know or is this a new problem
Yeahh 3 bolts and I think there double-sided stickey tapped on so give it alittle yank.
did that seems too big ta fit outta tha hole
If its a MK4, i`ll have a quick look in my Haynes if you like??
please mate would like it done the weekend
please mate would like it done the weekend for him
Right, i cant scan it in cause its connected to a diff PC and i cant get it to work, so i`ll type it up....
Quoted almost word for word;
Tailgate lock handle removal.
1. open tailgate, remove trim (inside the recess for your hand should a handle retaining screw)
2. Disconnect the pull rod from the handle (also says to unclip central locking rod but that doesn`t apply to you)
3. lever out the securing wire clip and detach lock cylinder from the handle
4. remove 3 torx retaining bolts and remove handle
And thats about it. There are some pictures, but its pretty much just remove all the rods, cables, screws etc and it should come out.
Hope this helps.....if it doesn`t, i`ll try and get my scanner working and put the pics in, not that i think they`ll be much more help.
brilliant thanks works a treat .......
Lovely...i take it you forgot the pull rod? or taking out the lock first?
all out thanks mate i,d left the lock in once i got the lock out it was a breeze ,cheers mate......
This is very handy I'll be undergoing this removal soon I hope! maybe this guide should be pinned??!?
