I need help on a SONY XR-3759 stereo removal...
I'm trying to remove my Sony XR-3759 head unit from a 1997 MK4 Polo.
I've looked in to it and apparently you need special keys to remove it, but I haven't got them. I have been told that they are available from car entertainment shops.
Is there any way to remove it without the keys?
I've removed the glove box, and I can see behind the unit, but I can't see any clips that are holding it in.
Thanks.
  • Replies 10
  • Views 6.2k
Thanks.
yes you do need radio keys idealy , but there is a way of removing sony headunits with out them , idealy u need two long thin scewdrivers and slide them down each side of the head unit in the middle this should release the head unit from the crable ,, i know this as put a new headunit in my mates car yesterday and he had a sony on in there , and this is how i got his out , i could be wrong but the best bet is to get some radio keys for it , or ask one of your mates if they have a sony headunit and have the radio keys u can borrow , as i think there all the same !
Thanks.
You have to take the surround off the cd (the little plastic loop around the face) then push somethin flat into the middle of it, you can see the grooves normally where they go into. then push towards the outside and pull the cd.
*If its your first time removing a stereo, probably safer to try and get some radio keys for a sony*
Where abouts are you? if your anywhere near i could pop some over for you?
I'm in Herefordshire.
And, how do you remove the surround?
I'm not too bothered if it breaks, because I'm buying a new stereo and this one doesn't work properly anyway.
Haha too far for me sorry :lol: The little plastic bit around the face just pulls off iirc. Then just slide a flat thing in, but make sure u do both sides at once. Once out if your changing the stereo i guess you'll need to take the cage out aswell :thumbsup:
Okay, thanks.
Another thing... (As I know nothing about car stereos.)
If I buy another Sony stereo, will it just be a case of plugging it straight in and using it, or will I need to fit new connections and plugs to the existing wiring?
This is what I plan to get: http://cartexim.home.pl/allegro/GT31U4.jpg
Ye i think that where you unplug it from the car, normally 2 plugs, will just plug back in again :)
Awesome, cheers for all the help.
use 2 table knives, slide them down either side of the headunit and then tug it out, the unit you will buy will have a new wireing loom that will plug into the existing 2 plugs, also make sure you connect the aerial as well! then slide it in and clip the face on.
Jon
No worries :) First time iv actually been useful with tech stuff i think :lol:
