gear knob change
hi i recently purchased a mk 4 6n2 polo gear knob with the gaiter on it....i wanted to know if any one could help me as to how to take the gaiter off as i want to put a new one on and also how to change my gear knob on mi 6n...i dont know how to take if off the gear stick and putting the other one on....please help =D
  • Views 1.7k
lift up the "leather" bit, and you should see a metal clip running round the gear stick you need to loosen it, and then the old gearknob should slide off , along withe the leather bit attached to it
how would you loosen the clip? i spent an hour trying to do it...
I got a flat screw driver in the middle of the metal clip and pulled it off
