body rust....what should i do?
hi there,
i got two spots rust on the drivers side of the car...wanted to know how to get rid of them? please help anyone =D
the only way to properly get rid of rust is to remove it,,there are loads of treatments etc out there that'll cure it for a month or two but it will just come back. Depending how bad it is either replace the panel or cut out the affected part and weld in new.
May seem a little drastic but thats the only way of guarenteeing it wont return.
the bodyshop that did my simply rubbed down any panels affected by rust and smoothed over them,,one year on its worse than before i had the reapirs done.
Hope this helps mate.
Sand it down with some 240 grit, get some "Krust" from halfords for about £6 paint it over the rust, wait half an hour sand it down with 800 grit and prep to spray. Only do this if you are prepared to spray. If not, let it rust away.
All i do with my bits of rust is grind them down to shiney metal, rust killer it, prime it, hammerite silver it, car colour paint it and lacquere it.
But then i`m not too arsed if the colour matches, because i only do the small bits before they get too bad.
No point in cutting it out unless its a hole already.
Just get it down to bare metal by either sanding it lots or grinding (or a bit of both with a flap disk)
Then you may need some filler (not much) to get it back level again with the rest of the body work and paint over it. Oh and treat the bare metal before you filler.
Take it back to bare metal with sandpaper, paint stripper, a grinder or all three, depending upon the severity of the patch. Very often you find a rust patch is bigger than it appears through the paint, but normally if you catch it early enough it won't cause too much damage.
Once you're back to bare metal, give it a coat of rust treatment - I use the Hammerite stuff that's labelled as beige but actually looks pink that you can paint or spray on, available from Halfords or any good motor factors - being sure to follow the instructions. Be sure to give it a sand, fill and finish with body colour paint or at the very least waterproof paint so that the rust doesn't come back.
If the rust is near the bottom of your door, check the drain holes aren't blocked as that can cause it to come back. Easy way to do this is open your door, have a look underneath and clear off any muck, there should be one or more little holes you can poke a bit of wire or similar through that allow water to drain out. If the rust is at the top of the door, where the window starts, it could be a dodgy seal trapping water rather than keeping it out in which case, if it's bad, replacing the door is often a better option as it's a tough repair, but do try the above first as it may just be a little patch of surface rust.
I've dealt with rust on all sorts of cars, but the Polo (at least Mk2 and Mk3) seems to be quite good at only suffering from minor spots, on the whole, so you should be okay *touch wood*.
