fuck, lost my locking wheel nut key!
Hi there,
I've resprayed two of my wheels the other day, and when i meant to put them on, I've realised that its missing,
So what can i do to take my wheels off??
HELP!!!
  • Replies 17
  • Views 1.2k
Drill it out, buy a locking wheel nut removal kit, take it to a garage. There are a few ways but it might be best not putting them on a public forum...
where can i get that removal kit?
irwin bolt grippers.
can get locking wheel nut removers from halfords
I've heard if you hammer a socket on thats too small , it works to remove it.
lol I've done this before mate..
I tried drilling them out but they were fucking solid and barely made a mark on them.
Got one off by getting a smaller socket onto it but all the others were too tight and i fucked one of my wheels in the process.
In the end a guy at work welded a huge bolt onto the and we managed to wind it out without doing any damage at all.
I found the removal kits were crap. They are basically 4 different sized sockets with a left hand thread in them that in theory cuts into the wheel nut and winds it out,,however the thread doesnt start until halfway down the inside of them so does not grip at all.
Hope you get sorted pal.
ill try that removal kit, if that wont work ill go to a garage
cheers guys!!
the removal kits are crap, but if you get the same tools supplied in the kits from a decent tool manufacturer you`ll be laughing, those irwin bolt grippers have a good reputation in the vw circle
the kits are quite pricey also.. do you not somebody handy with a welder??
i went to local garage, gave them £15 to do it, job done, new wheels on :D
just wack a socket on (Impact are best, usually 19mm for me) with a small extention. Then shock it out either with a impact wrench or mallet etc.
i like the weld idea tbh.
Works for me, had to do it for a friend who lost his when he put his space saver on at th side of th road, only took half an hour or so easy. 19mm is what we used aswell if i remember correctly
Just take it to a decent tyre fitting centre. Fiver per bolt, if that, and it's done in 10 minutes.
or as he said about 11 hours before you posted this...take it to a garage and get them to remove it lol..as he has already done.
Jon
The ones you can buy anywhere for £20 are crap. I've got a set of proper ones and they work every time without fail.
I'd rather wack a socket a couple of times than pay some garage £20 to do it...
