Front Left Wheel Hub
Just jacked up my car and was slightly moving my front left wheel and noticed it was wiggling about quite alot, been told the hub needs replacing.
Any help would greatly be appreciated.
Thank you
Mike
Edited by Mike1990
  • Views 982
Sounds more like track rod end/bottom balljoint to me mate.
Well, i've took the wheel off and the hub still moves quite alot. Think it's the bearing at the back of the hub.
So does it move backwards and forwards or side to side? Is your driveshaft nut tight?
It moves backwards and forwards then side to side mate
I'm guessing it won't be safe to drive then :-(
