Mk2 Breadvan rear arch de-trim
I almost forgot about this, but then I remembered I'd taken some photographs. I've seen lots of lovely Polos out there but I've never seen anyone detrim the rear arch on their Mk2. Now, I know the little bit of plastic is there to protect against stone chips but It was never a problem with mine when he was on the road for a couple of years of driving about all over the place after the trim was removed.
It's much cleaner and smoother but the compound curve is a nuisance to rebuild after the trim is removed. I'll put together a how-to post when I redo the driver's side in the next few weeks (a bit of necessary bodywork damaged the fill), but for now, here's a shot of what it looks like on the good side.
  • Views 1.2k
I have done the same :-D ...although not quite as well as that.
With the bump strips removed as well it does look a lot better....nice job
both my mk2 and mk3 polos i did that too looks good imo
Banana removal lol.
I had to do mine because there was damage right where the trim was. what a hell of a learning curve for welding!
Does look a lot better but I've found with living in an area with farm tracks and rough roads I've got a lot of chips so might consider some sort of stone chip protection.
