turbo conversion now working
made an adaptor for the turbo water supply using a piece of exhaust pipe and part of the original solid water pipe from my spare k03 turbo, both just lying around in my garage:
Turbo conversion now worjking:
Went out for a drive in it today (only ten minutes or so mind). It runs OK considering the ignition timing is currently guessed, the idle isn't set and it needs a proper remap (will be off to pay Andy Strange a visit soon). Only running about 6psi of boost at the moment until the remap and other loose ends are sorted out. Also need to finish the aquamist install.
  • Views 1.6k
Looking good dude, you got a second lambda boss?
looking good, what kind of power you expecting when you have the niggles sorted?
Good stuff! :D
yeah there's another boss a couple of inches lower down the pipe than the lambda.
hoping for around 180-185 once it's properly mapped and stuff. Will be running 18-20psi boost.
mmmm very respectable should pull well in that little thing,
wish i had that kind of power but unfortunately i have around a third :ninja:
