Door Lock & Electric Window Switches
Hi,
I think my 6n was broken into at some point as the driver door lock has a different key to the boot, pass lock & ignition. I'd like to swap the drivers & passenger locks so I only need 1 key to get in and drive the car. I'm handy with tools and would like to know if this an easy job to do?
Also the electric window switches are wired in opposite directions! Pass side I push at the bottom to lower the window, but the switch on the drivers side wired the other way around, you have to push it at the top to lower the window. It is easy to remove the part with the switches on so I can swap the wires behind?
Cheers,
:thumbsup:
Edited by Gunzi
  • Views 834
I can only help with the switch, and yeah its pretty easy to get out but you don't need to re-wire it.
what's happened (I think) is that the bit of the switch that you actually press (the bit that moves) has been put back into the switch upside down. so...
pry the whole e/w switch out the dash, the bit of the switch that you press (the only bit that moves) needs to be pryed out of the actual switch. stick a knife down either side of the switch to help.
turn the piece that you've removed the other way up and press it back into place and that should be it working
hope this helps and isn't too confusing,
good luck wi the lock
Cheers for that. So it's just gently prise the switch out and turn it the other way around. Sounds easy enough!
I'll do some more searching on the locks :)
Ok electric window switches were as simple as you said.
The locks were really easy too, it was just one star bit per side, and the handle with the locks slid out. Then I just swapped them over and now I only have one key to get in and start the car.
Happy with that :)
