first car
I'm planning on getting a mk4 polo very soon, it will be a 1.4 8v and i just wanted to find out a couple of things
whats the bhp
can u make them fast or nippy
what are the common faults on them
and will mini ultralites be easy to fit to a mk4 polo?
cheers matt :)
  • Replies 8
  • Views 994
whats the bhp
cheers matt :)
heres the info according to parkers on the polo 6n http://www.parkers.co.uk/cars/specs/Detail.aspx?deriv=10674
its running 60bhp from the factory
yes you can get them nippy with a cam and a 4 branch manifold to straight through exhaust system, but i personally think mines pretty nippy from standard, 4th gear performance seems really impressive as mine seems to get a nice powerband from 3k rpm and just keeps pulling
but to make it genuinly fast you need to do a big block conversion of some order...maybe a 20vt transplant?
common faults are that they are prone to rust! they rust everywhere and are much worse than the mk3 for it rust wise! also my cars done about 70k miles and the thrust bearing and wheel bearings are already on their way out
not sure about the mini wheels but iv not personally seen it done, but that doesnt by any means mean it hasnt!
hope this helps
Jon
if you want fast you want a 16v to be fair
AFH 100BHP FTW
but if he wants a 16v hes got to be able to insure it etc... its alot more for the 16v
Jon
Personally I found the 16v quotes to be only slightly higher than the 8v's
So a valver for a first car it was lol
cheers for the help guys and i got quotes for a 16v and the cheapest was 3k!! lol
so its gonna have to be the 8v
faults... soddin electric windows! My drivers side doesn't work and my passenger is slow as it can be without actually stopping! rust issue isn't bad on mine... anyone owned a pre 00's FORD? thats a rust problem! :lol:
as said, engine is definatly a strong one, nippy aint the word i would use as compared to other similar engines it's quite a low revver... but torquey is how i would describe it, nice low down pulling power! but a 1.4 is still a 1.4 8v or 16!
i know insurance is more, but you suggested an engine transplant...
a 16v will be cheaper than an 8v with a 20v lump in it.
Edited by ben_reza
