6n1 window problem (HELP)
When i wind my window up and down on the passenger door side i get a clunk half way down
any idea what the problem could be?
  • Views 962
I have the same problem is the window stiff to wind up?
yerr it is
what do you reckon it could be?
have you took your door panel off to see what it is?
the window has fell of the rail will need to remove the door panel replace the window onto the rail grease up all the joints and pop the panel on easy job 20mins max
