how do i remove window winder handle?
apparently it is easy?
I'm having problems doing it
  • Views 1k
Can you describe the problems you have?
I've done it now thanks anyway
however how do i remove the door panel?
It would be nice if you mentioned your car....
Anyway in general remove the door pin (unscrew it) remove the cap from the inside door handle and unscrew the two screws there. Grab the buttom right corner of the panel and pull it. It requires quite some force to come out and dont be frightened by the horrible braking noises it does while you pull it. Care must be taken with the mirrors adjusters cause they are screwed into the panel.
Edited by Capamaru
