Removing rear 8v bumper? HELP!
hey guys I'm sorry if this has been asked a thousand time as I'm sure it has but iv searched and cant find exactly what i need to know...
basicallly i am taking off my rear two part bumper to replace it with a 16v one but i cant seem to pull it off, i have undone the top four bolts that are just below the boot rubber lining but it feels like somethings holding it on at the botttom... it there some more screws i cant see underneath?
also the lower metal part of the bumper, does it come off? or does it just stay on there with the 16v bumper over the top?
cheers
steve
  • Views 781
cheers
steve
M8 there must be 3 + 3 torx screws on the inside of the rear wheel arches. After you unscrew those plus the four screws under the rear boot lid you must pull the bumber. It is hold in place by 4 clip like things from the inside. There is no danger to ruin them so give it a good pull and it will come off. The lower metal part of the bumper stays with the upper one and it is totally removed in order to install the 16v one. If you need more help tell me and I will upload an image.
Edited by Capamaru
cheers
steve
cheers mate,
i managed to get it off in the end!.... i already done the arch ones, and found two extra 10mm bolts to get the lower part off (one on the side and one underneath) but they had been sprayed over so i needed to pick the paint off with a screwdriver to allow the spanner to go over the bolt!
but yeah loving the 16v bumpers now!! 16V BUMPERS FTW!! lol
steve
