Wheel help!
Help is needed again peoples!
I'm in the process of selling my Th lines and I've been offered a set of BBS RS's porsche fitment
8.5 and 9 x 16's - High ET's ET56 and 36 and if i put 20mm adaptors they will have et36front and et16rear
The question is would this be ok for a polo, bearing in mind my archs are pulled as well or are they way to far off?
I've been offered some RM's as well ET33 6.5 standards and i was going to build another set like my old RMs to 8s and 9s again which should be ok i think!
Help needed please!
  • Views 780
Help needed please!
9x16 et 16 should be sound make sure theres stretch on tyres though
et36 on the front definatly wont fit.....you wont move anywhere....i had 15x8 with et30 and the car didnt move with them on the fronts!
How and why didnt it move dude?
Inside of the wheel will be close to the suspension,
I got 8's et 20 and i can just fit my hand inbetween the inside of the wheel and my suspension.
Edited by H@wK£R
The rears should fit in theory, as they are only 4mm off mine in terms of offset (mine being et20), and i assume your arches are pulled more than 4mm lol..
Only issue would be how low you got it, but i reckon it'd be fine..
Waht happened to going low again anyway? 16's? tut tut..... :lol:
Sorry for not explaining....mine were 15x8 et30 and the inside of the wheel was touching the suspension, there for the car couldn't move and I had to get spacers to space them out a few mm so they fitted! I just assume that 8.5x16 et36 would be touching the suspension, even if the arches were pulled etc....
