fixing new number plates to the car
got my german plates today from plateman, and i don't really want to drill them to fix to my car, i was thinking velcro? because if i get pulled i can change them straight away. where can i get velcro from tho? will they have it in halfords???
  • Views 1.4k
to be honest mate, if you get pulled nowadays you get pulled. if you have german plates and the fuzz pick on you, you dont have a leg to stand on so doesnt really matter if you have velcro or not.
the safer option is to us the foam double sided tape as it has a good bonding glue on it so people cant just come along and rob your plates lol
Jon
halfrauds velcro pads, job done
people can still nick them with sticky pads easily, more likely to do damage to the car too, Halfords heavy duty Velcro I would use.
What these men said above, halfords velcros the way forward :thumbsup:
Is it easy enough to get the plate straight and level when using velcro?
Just put it on, if it isn't straight pull it off and try again?
Yeah pretty much that. You want the two bits of velcro to be perfectly lined up though, more contact means more stickyness.
Only thing is, velcro allows you to remove your plates, but it still leaves the other side of the velcro on the car.
If only there was a way to use some high power magnet or something attatched to the inside of the bumper and then on the back of the plate, so you could just take it off and on.
Obviously not a magnet because it would attract all sorts but something like that.
Quick release plates have the highest danger of being nicked - you aint kiddin anyone that you're going to remove them everytime you leave your car unattended.
If you cover the entire back of the plate with sticky foam (three quids worth from Hobbycraft),it aint going nowhere without you making a right mess of the thin aluminium plate,yet it can still be done without marking the paint.
If the plate is so illegal that you have to carry legal ones in case you get pulled over,you're on your own - because that'd be bloody stupid.
If you want to be able to swap the plates when off-road at shows,despite the quick release security flaw,stick on some plate holders (you can get VW ones) and then you can swap plates in seconds.
