Adjusting clutch cable on a polo 6n.
Hey,
how do you adjust the clutch cable on a polo 6n?
is it a easy job?
  • Views 7.2k
no body?
Not sure if it depends if its rod or cable, where as mine is a Rod Type no idea if that changes how the clutch is adjusted, is the Clutch Pump Press or Cable lol i have no idea >.<
you have confused me horrificly haha,
um, it should have automatic ajustment i do believe.
ah i duno I'm confused!
It will either be self adjusting one so you shouldn't need to touch it but they aren't that great and wear out
Or one you can adjust yourself. Simply done by two locking nuts (10mm I think) on the end of the cable. Just need to be un-locked and then can adjust it, and make sure you lock them back up.
iirc it's tighten the cable to lower the bighting point and loosen to raise biting point (don't quote me on that though, I always get confused with it :lol: )
looking in the haynes manual is says that it should be self adjusting, but I'm not too sure to be honest, ill have a look in a bit later and seee what i can do.
