6n Only has front speakers as standard?
Well, I just fitted a new headunit to my n6, and while I was pissing around with the balance and stuff, I realised that it only has speakers in the front? Lol.
I hadn't even thought about it before.
Will there be any cables fitted in the car near the rear? (So that speakers can be fitted in the parcel shelf), or do you have to run cables all the way through the car yourself?
Thanks. :)
Edited by Jamez
  • Replies 13
  • Views 1.5k
Thanks. :)
This is the wrong place for this thread, but you have run the wires from the boot to the headunit yourself.
Yeah sorry, I realized that after I posted it.
But okay, thanks.
I'll be fitting some soon. :-D
But okay, thanks.
It's no problem :D you just having the fronts and rears connected to the headunit? or you wiring a amp?
Hadn't thought about that.
I don't know much about car audio.
Whats the advantages of having an extra amp instead of just running them off the one in the stereo?
The amp will allow the speakers to run at their full potential which means louder and clearer sound, but i would recommend getting some uprated front components before connecting them to the amp.
Edited by Mike1990
Guess you got the old one out then dude? ;)
when i done mine i had wiring the the rear but no speakers :?
not that its any use cos I've got a amp in the boot to run the rear speakers :lol:
That's probably because the previous owner had speakers in the rear but took them out before selling the car
no its proper wiring, plugs and go's into the loom some where, looking at it its never had speakers in the rear cos there's no holes where they would have been bolted and when i got the car it was 100% standard even had the standard fit VW/sony head unit in it
Rear speakers are gay.
My car has 2 midbass drivers and 2 tweeters in the front, and a subwoofer in the boot.
IMO rear speakers ruin the sound. When you go and see a band they are infront of you, not behind you. Just my thoughts.
Rear speakers really aren't neccesary.
Yeahh. :D
Couldn't be bothered to buy some removal keys so I used force and some flat bladed screwdrivers!
I was careful to not mark/damage the car though.
The new one went in a treat!
run some speaker cable along the sill trim and chuck some 6 X 9s in the rear shelf,and while your at it add a power cable and remote cable ready for amp and sub
6x9's??? why?
