coilover fitting guide for a 6n2?
searched here and uk polos and can't seem to find one, has one ever been done? tried to fit em yesterday but couldn't get the plastic cap off lol, even my haynes manual wasn't much use.
thanks
  • Views 1.2k
loosen the top mount bolts (3 x 13mm head) with the car jacked up and the caps should pop off fine, sometimes they get pinched between the topmount and the body.
i did write a how to before but it was just talking someone else through it on their thread - never made my own.
thanks for the reply.
I did undo the 3 bolts, and the two at the bottom and wiggled the suspension around, but still it never came off so i just got the stanley and cut it off. in the end i couldn't get the bolt undone from the top of the strut so i had to put it all back together.....
Edited by leescreen123
it's easier to undo the nut when the car is not jacked up and you need a 7mm allen key and a 21mm plug socket so you can hold the strut with the allen key.
