polo headlights - HELP
i bought a headlight off ebay, but i have headlight adjusters, does any standard headlight work with these or do i need a special headlight?
i dont ever use the adjuster, just stays at max but scared it wont fit.
i read on here theres something about 7 pin and 9 pin
  • Views 912
Electric adjust are 7 pin. Non electric adjust are 4 pin. If you get the wrong one, the electrics won't plug in.
but will the headlight still work ok?
It might work if you cut off the connectors and manually connect the wires from the adjuster to the head lights
Edited by Mike1990
kk, theres nothing else as dont want to mess around with electrics, anything easier?
Get some electric headlights
