Super Unleaded / V-Power
never used Super Unleaded / V-Power much of a difference or anything? i assume it would be ok run the 6n valver on it?
  • Replies 19
  • Views 1.9k
no, it'll blow up
Naa you should be ok man, this stuff on the other hand...
:o
no, it'll blow up
hmmm i thought valver could cope with the higher octane level?
:o
lol wtf
Edited by Ian.Southall
basically mate youll be fine.
shell v-power is the only fuel that is garunteed to be 97octane at the pump. the others i wouldnt trust with my left nut.
RON is the fuels ability to resist knock. so if you have a high boost/high compression engine then a higher octane fuel will mean that the engine can take more boost/higher compression or more ignition advance before you get knock (detonation/pre-ignition) which will destroy your engine.
You might notice that the car is possibly abit smoother on the higher octane, but the difference isnt amazing. For a standard engine, stick with the cheaper stuff IMO.
no, it'll blow up
Seriously? You think they'd try to sell a fuel that makes your car blow up? :lol:
I use V-Power in my GTI and car runs well. Haven't filled up with normal unleaded so i'm unaware of the differences at the mo. Although my bro has used normal unleaded and then V-Power and there's a noticeable difference between the 2, V-Power being better of course. He has an Impreza STI which is 330bhp. They say V-Power and similar fuels like BP Ultimate have a better effect with performance engines. :thumbsup:
PS. LOL @ the octane booster! Mate in Halfords told me enough chav asbo's buy shit loads of that LOL
Edited by DJ_Troopa
BP fuel is shit
i use tesco coz i get double reward points :-D
shell fuel ftw
tesco 99 ftw
alot of my mates can only only run v power nothing else because of there mappinng
you need to use about 5 to 10 tanks for the system to get us to it to notic any differance
i dnt care bout the fuel its guna be slow whatever i put in i use shell for the gal on the counter :lol:
My compression ratio is 11.5:1 and the bike induction gets more fuel/air in than standard.
So the actual compression is higher than standard,equivalent to at least 12:1.
It does get some 95 ron on occasion,it wont blow up on the fourcourt,but it runs best - and is most economical - on Tesco 99. Good on Shell 97 too. I dont know about BP - i cant afford their prices.
The only petrol that can damage your car is 95. That is,if your car isn't designed for it. You're safe to run on 95 if it says so on the label in the fuel cap.
Running a 'normal' engine on 99 will not make it go faster.
Those FQ version Evo's can only run on V-Power so i'm, told, bit of a ball ache, the only Shell garage near me is like 4 miles away, glad I've only got my Polo :lol:
Mk4 16vs are supposed to be run on premium fuel! It says so in the handbook!
run my 16v on BP ultimate makes it run nice and smooth
I use BP Ultimate all the time. No difference to power output obviously, its only a 1.6-litre engine! However, it is smoother-running and I do get better economy :-)
I run mine on total excellum, its loads smoother & there is a defenate
improvement on mpg! BP Ultimate, & V-Power make the car run better
but doesnt last long!
Plus its bloody expensive :shock:
Your lucky, the nearest Shell garage to me is 32 miles away.
VW say valvers should be run on 98RON. Mine runs alot better on Shell V-power. Not much difference with 95RON however just a slight bit more mpg and no lumpyness in the idle.
Someone said to me a few days ago "I need V-power for the way I drive" I had to leave before I died laughing.
