Mk2 Speedo/Milometer
The milometer/tripmeter in my '88 Mk2 breadvan doesn't work. I'm guessing it's a fault with the mechanism inside the speedo that's the problem.
Is it possible to separate the speedo from the cluster and replace just that part alone or is it an all-in-one item with the clock/rev counter?
Yes it's possible to swap speedos over.
That's great, thank you. :-)
Is it true that the clocks from a Mk2 Golf will fit a Mk2 Polo?
no golf 2 clocks dont suit.....mk1 are similar
hey there, also if you buy a new speedo and dare to take it apart, you can quite easily put your old mileage in the new one.
Thanks for that, I'll give it a go.
