which Engine Size?
I've got a 92 On a K plate Mk3 genesis and just over a year ago I swapped the engine,the scrap yard I got it from said it was a 1.0 but for a 1.0 it goes like stink!! I'm Thinking it actually could be a 1.3.Is there anyway I could find out apart from checking the engine number?
Daz 8-)
  • Replies 26
  • Views 2.5k
Daz 8-)
Maybe VAG-COM
can't use vagcom on an mk3.
is it stamped on the block?
then again even a 1.3 going like stink ?
Cant see anything on the block mate,Well I say goes like stink I mean It just goes very well! for its engine size!
Is there anything on the block etc that a 1.0 wouldnt have?
you can use vagcom on a mk3 but I dont think it'll tell you the engine size. If you look at the engine number the first bit of that is the code which will tell you what size it is.
could be a 1.0 with a 1.3 throttle body? I've got that and it moves for a 1.0!
Wheres the engine number mate and I will check it out 8-)
has it got a odd shaped object near the front of the engine bay
make woooshing noise's and spin up in 3rd?
lol
maybes its got a G lump in
haha
Engine number is stamped into the side of the block,between the gearbox casing and waterpipe junction.
by the sounds of it I'm pretty sure its a vr6 lump you got in there :)
An easy check could be to measure the throttle body butterfly. Think its 38mm or 42mm or something on a 1.3? Sure someone will know the exact size. its much bigger than a 1.0 throttle body butterfly anyway.
did you put new engine in the back? could have a bike engine in there........ :wasted:
lol
haha
I wish,and so does Danny Lol
The thing Is I havnt mentioned which I maybe should of...... :oops: Its only got 30k on it :? But still it goes very well....
Edited by mucker
Engine number, take a picture and compare it to my 1.0L ???? if its size it different then it may be a 1.3L
Here we go.....
Looks the same, Id looks for the engine code now unless someone can tell easily
Cant find the engine code,there is to many pipes about lol
ljmnitro - you have a 1.0, take the lid off your airbox and try and measure the diameter of the throttle body butterfly.
mucker - you do the same and compare, if its the same measurement its a 1.0, if yours is bigger then its not (or it is but it has been modded)
Anychance of a look of what it is
i know how to take it off etc and inside teh airbox thers the filter then a hole. . . .
You lads aught to get yourselves a Mk3 Golf 1.8 Spi Throttle body on your 1.0l Mk3 Polo’s I had one on my old Mk3 Polo and it went almost aswell as a standard GT . I did have a straight trhough exhaust and fook all in the thing though .. . No rear seats ect ..
It was jokes !
Edited by Stealth
It was jokes !
haha id love to but with insurance well its going to be expensive if i end up keeping it for anotehr year on top i may do a GT conversion
Sorted people,the block still has its sticker on it and its a 1.0 (it says 1.05 on the sticker anyway lol)
It was jokes !
does this work??
and what engine code is the SPI, is it the ADZ??? hope so no someone who as one spare! lol
Yep it works a treat and its a straight bolt on part aswell ..
Drinks fuel a little more but definatly adds to performance no end ..
A 1.8 throttle body is way too big for a 1 litre. A 1.3 TB would surely be better and still give good MPG?
