Mk1-3 Stainless Exhaust Manifold
well now I'm fitting the AFH this manifold is redundant,
I'm sure you all kno what one is and looks like,
this has a lambda boss already welded in and will come with a plug nut for those running carbs.
this has done less than 10 miles and has just got that gorgeous burnt golden colour to it.
i paid 160 for it but i would like £100
id rather not post for obvious reasons, i am just outside milton keynes on the road to santa pod
cheers all
J
(when it was new)
Edited by Rod Stylz
  • Replies 12
  • Views 381
is this just a manafold or downpipes also ?
its all one piece dude, comes off the head and curls under the sump.
i cant confirm yet but will prob come with a matching de-cat pipe too!!!!
o ok cool will it fit a polo g40 do you no ? also what bore is it ?
will this fit a 1.1 mk1 golf engine? if so then definately interested.
should do mate, they are the same engines
you have pm
just to confirm peeps, this will bolt straight up to a standard centre section as the decat pipe is the same bore as stock.
what size bore is it matey?
Its approx 42-43mm like i said above it bolts straight up to stock centre section.
Prov sold!!
would u pm me if it dont sell please?
closed by me.
