Would it fit?
Would the cam out of a polo gt 1.3 8v fit into a mk4 6n 1.0 8v AER?
  • Views 719
bump
if you find this out or find a beter cam that will fit pm me please
cheers
loz
Yes,but i doubt the timing marks will line up correctly,so you'll have to match up the crank and cam positions.
To get the cam timing right,you may need a vernier pulley.
The marks are likely to be a few teeth out though,so if you line them up as marked and then turn the engine over,the pistons will punch the valves.
