fitting a Mk2 front grille and lights to a Mk3?
is it actually possible or do you have to do a hefty amount of work to get it to looks right?
max
  • Views 1.3k
max
Don't think the mk2 front grille will fit on the mk3 unless you do some work on it
The Mk.3 front end was only tacked onto the Mk.2.
That said, it's still a fair old amount of work to do, and the bottoms of the windscreen pillars need some reshaping to fit the front wings. It has been done though(and the other way round).
hmm , just allways liked the front end of mk2 and side and back end of a mk3 :(
lol
I'm with you on this one, dont liek the mk2 back but mk3 looks so much better...prefer the mk2 front to mk3, would like to interchance them when ever i feel like it lol. hope its easily done!
There's quite alot of panelwork involved.
Slam panel,front panel,cross member,bonnet,wings.. The facelift actually extended the car,with extensions added onto the chassis legs. The earlier grille attached to the earlier panelwork - that the facelift model doesn't have.
Scuttle panel is the same,the difference at the end of the A-pillars wouldn't really need addressing,would just be a quirk.
But it does require the front end to be stripped down to the inner wings and re-panelled from there.
why not put the mk3 rear end on a mk2 if you want that look
