MK3 dash in MK2 coupe
HI , I have a MK2 polo coupe with a 1.4 8V polo engine fitted, and I have the standard coupe dash meaning no revcouter and other clocks. Is possible to fit a Mk3 polo dash in my MK2?
What are the problems I could encounter and has it been done before?
Picture would really help
CHeers guys :-D
  • Replies 8
  • Views 2.4k
why not just fit the clocks from a coupe s that does have a rev counter?! it'd be a lot easier, you can even keep you original mileage that way too
i would imagin it is a straight swap, same chassie same size etc, all you might need is the dash, switchs, and the bar. not seen it done though. would like to see it.
good luck
Thanks guys, I never seen one myself but as g40Jon said it same size, the mk3 is just a facelift right? so I wil give it a try, time to find a donor car then. Will try to keep posting if I have got any updates.
tryed it first you would have to change the plug (no biggy) but where the bulbs fit in the mk3 clocks they catch the top of the mk 2 dash swapping the dash has been done but not by me yet watch this space
You can just swap the binnacle,I've seen facelift clocks in a pre-facelift dash,same size. Remember them saying it was quite easy. The problem bits will be what Bort said.
Also MK1 Golf/cabriolet clocks fit. Even Golf MK2 with a little hassle.
Easier than the entire dash,anyway.
yes of course and I guess the binnacle would be easier to source alone and cheaper as well.
not what i meant! the MK2 COUPE S! has the same style clocks, only it has a rev counter instead of a clock. other special models like the ranger also had a rev counter. the clocks themselves can be stripped down so you can simply put your speado into the COUPE S clocks to retain your original mileage. get it?!
The dash swap is more than just a bolt in job.
The steering column support bracket that is welded to the bulkhead is a different shape and fouls the back of the dashboard. To get round this, you have two options...
1, Cut the bracket away and weld in a Mk.3 item(what I'm currently doing)
2, Cut the back ot the dashboard and the clocks away to clear the support(not very professional)
There are other issues too such as relocating the lower brackets(easy) and one or two wiring probs(nothing too major). You will also need a Mk.3 column as the Mk.2 lock sits in a slightly different place and will look odd in the Mk.3 plastics.
I have loads of Mk.3 dash parts that are going in the skip this weekend. If you want any to play with, come and get them for free!
